Script for corelation alarms
Solved1.14K views9th December 2024
Matija Kos [DevOps Advocate]72 12th November 2024 1 Comment
How to create script that enable one corelation rule?
Matija Kos [DevOps Advocate] Selected answer as best 9th December 2024
Matija Kos [DevOps Advocate] commented 12th November 2024
Some corelation rule
Miguel Obregon [SLC] [DevOps Catalyst]22.32K Posted 12th November 2024 0 Comments
Hi Matja,
Please find below a similar question:
How to enable/disable correlation rule from code?
Hope it helps.
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 12th November 2024
