Script Failure (Dom Editor) while using DomInstanceValueFieldDiscriptor
Solved4.27K views14th August 2023DOM DOM Editor
Ladan Razeghi [DevOps Catalyst]1.09K 25th April 2023 3 Comments
I'm using Dom Editor and while trying to link a field in one section definition to another section I receive this error.
Script Failure (Dom Editor): EXIT: "System.InvalidCastException: Unable to cast object of type 'Skyline.DataMiner.Utils.InteractiveAutomationScript.StackPanel' to type 'DOM_Editor_1.FieldDescriptor.Panels.DomInstanceValueFieldDescriptorPanel'.
at DOM_Editor_1.FieldDescriptor.PresenterHelpers.DomInstanceValueFieldHelper.OnFieldDescriptorChanged(Object sender, ChangedEventArgs changedEventArgs)
at Skyline.DataMiner.Utils.InteractiveAutomationScript.DropDown`1.RaiseResultEvents()
at Skyline.DataMiner.Utils.InteractiveAutomationScript.Dialog`1.RaiseResultEvents(UIResults uir)
at Skyline.DataMiner.Utils.InteractiveAutomationScript.Dialog`1.ShowInteractive()
at Skyline.DataMiner.Utils.InteractiveAutomationScript.InteractiveController.Run(IDialog startDialog)   at Script.Run(Engine engine)" (see comment for more details)
Any suggestion?
Ladan Razeghi [DevOps Catalyst] Selected answer as best 14th August 2023
Thomas Cauwelier [SLC] [DevOps Advocate] commented 28th April 2023
Hi Ladan,
I’m not sure if you still need the DomInstanceValueFieldDescriptor, but the new version with the fix is now available on the catalog.
https://catalog.dataminer.services/catalog/3195
The fix is available in version 10.3.3.4 & 10.2.8.5 depending on your DataMiner version.
Note, we discovered an issue with the installation process.
If the installation fails, try to upgrade DataMiner to version 10.2.10 or higher.
Ladan Razeghi [DevOps Catalyst] commented 28th April 2023
Hi Thomas, I’m using version 10.3.4.0 and still have problem with installation. Deployment fails and noting is added to information event to know why
Marieke Goethals [SLC] [DevOps Catalyst] commented 6th July 2023
I noticed that this question has been open for some time now. Can you confirm if you have found a solution, so we can mark this question as solved?
Martijn Vanallemeersch [SLC] [DevOps Member]953 Posted 25th April 2023 2 Comments
Hi Ladan,
If I correctly understand your use case I would implement it like this with indeed the DOM instance field descriptor: where you have a workorder module with an order definition which contains one field that references to the client definition from another module. That way you will be able to have separate apps to manage clients & workorders & you will be able to reuse or references your clients in multiple workorders
Martijn Vanallemeersch [SLC] [DevOps Member] Posted new comment 26th April 2023
Ladan Razeghi [DevOps Catalyst] commented 25th April 2023
No, I can’t attached picture to the comment but everything is inside work order module. I’m trying to link definitions inside same module .
Martijn Vanallemeersch [SLC] [DevOps Member] commented 26th April 2023
Hi Ladan, linking between definitions is also possible within a module. For your use case I would still use that Dom instance field descriptor iso DOM instance value field descriptor as in your queries you will probably want to have other fields from clients such as contact person etc combined with workorder information
Kind regards
You are viewing 1 out of 5 answers, click here to view all answers.
