Scoping session variable using InitVar
Solved1.92K views14th November 2024session variable
Bing Herng Chong [SLC] [DevOps Advocate]1.73K 10th November 2024 1 Comment
Hi all,
Some advice is required on how to scope a session variable properly. I'm observing that my session variable is being scoped per Dataminer Cube session when the desired outcome is to scope it per Visio file.
At the page level, I'm using:
InitVar ---> ElementName:Element_A
I have several Visio files that does the same thing:
e.g.:
Visio file A
Visio file B
InitVar ---> ElementName:Element_B
Visio file C
InitVar ---> ElementName:Element_C
However, the end result is that I see the following when I load Visio file A first:
Visio file A
Visio file B
Visio file C
Bing Herng Chong [SLC] [DevOps Advocate] Selected answer as best 14th November 2024
Bing Herng Chong [SLC] [DevOps Advocate] commented 11th November 2024
I stumbled upon this post which answered my question: https://community.dataminer.services/question/visio-page-inititvar-behavior.
However, I'm open to hear any other ideas.
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 14th November 2024 1 Comment
Hi Bing,
The answer of Ive can apply to both page and shapes, but I would recommend to use it typically on Shapes. For page level - or initialization - I would suggest you to use the following: Configuring a page to update a session variable when another session variable changes | DataMiner Docs.
Important here is that you make sure to use the option 'ExecuteSetsOnInit' as well.
Kind Regards,
Jarno
Bing Herng Chong [SLC] [DevOps Advocate] commented 14th November 2024
Hi Jarno. Thanks for the post. I did experiment with this approach and found that it is working most consistently for the use case I'm working on.
