Saved filters option not visible for some users
Solved2.67K views12th July 2023Alarm Console Saved filters
Jan-Terje Larsen96 16th November 2022 0 Comments
One of our users are not able to select "Saved filters" in the filter-dropdown when creating a new tab in the alarm console.
In the below screenshot I would expect an option "Saved filters" after "View impact"
This is what I see with my user logged on:
Is there any rights-settings that enable/disable this feature?
Jan-Terje Larsen96 Posted 16th November 2022 0 Comments
Hi Ive,
When I log on, and select Saved filters, and then click the drop down - I can see quite a few shared filters. Some examples:
I guess "shared" could also mean "only shared with me"? Is there any way I can see all filters, and who they are shared with?
Jan-Terje Larsen Answered question 16th November 2022
