Same Element Property, Different IDs
460 views9th December 2025Element Property LCA
Bautista Solanet [SLC] [DevOps Advocate]838 5th December 2025 0 Comments
Hello Dojo,
I'm having an issue when deploying an LCA from one system to another. Both systems have an element property name "Workflow" with the same configuration. The LCA references the property in a GQI, however when we deploy the LCA, the property can't be found, and we have to edit it and manually set the property. I'm assuming the LCA is looking for the property via the Property ID and not the Property name, the issue is that there seems to be no way of setting this ID either when we add it or edit it.
So, the question here is there any way to either port over the property from one system to another or set the ID to match the other system?
Thank you,
Bauti
Sebastiaan Dumoulein [SLC] [DevOps Enabler] Answered question 9th December 2025
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.48K Posted 9th December 2025 0 Comments
Hi Bautista,
This is a known issue. Property IDs differ between systems, so after deploying the app elsewhere the property columns need to be selected again in the query builder.
We do have an item in the backlog to switch to a more predictable approach, likely based on the property name. However with this, if a property gets renamed, the problem would show up again.
