Running Telegraf on DMAs
709 views17th June 2026
Carl Stanley [DevOps Advocate]271 16th June 2026 0 Comments
We've had a request to have our AWS estate metrics in Grafana and that includes EC2s that are running dataminer. We're avoiding cloudwatch for cost reasons so wanted to run Telegraf on the DMAs so we can generate metrics for Prometheus to scrape. I believe Telegraf is pretty lightweight so I don't foresee any issues with doing this, but I wanted to ask if anyone has experience with this sort of set up or advice on it?
Thanks, Carl
Sergio Abreu [SLC] [DevOps Member] Answered question 17th June 2026
Sergio Abreu [SLC] [DevOps Member]221 Posted 17th June 2026 0 Comments
Hi Carl,
Not sure the exact dataminer metrics you are looking for but you might want to explore Grafana Data Source plugin | DataMiner Docs
SkylineCommunications/dataminer-grafana-plugin: Grafana plugin to visualize data from a DataMiner System.
note the remarks on the current state of the plugin.
