Running IAS from QAction
Solved281 views27th January 2026IAS QAction
Bautista Solanet [SLC] [DevOps Advocate]838 26th January 2026 0 Comments
Hello Dojo,
I want to run an IAS from a QAction, I've tried using the IDmsAutomationScript Execute functions as well as doing protocol.ExecuteScript and they both failed due to needing interaction, I am passing the User Cookie, so this doesn't seem like it should be the case. There's information that won't be accessible in the xml that's needed to run the script so it needs to happen from a QAction and not the XML.
Thank you,
Bauti
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th January 2026
Bautista Solanet [SLC] [DevOps Advocate]838 Posted 26th January 2026 2 Comments
Hello again,
I found this question answering my question: Unable to trigger interactive automation script - DataMiner Dojo
Thomas Cauwelier [SLC] [DevOps Advocate] commented 26th January 2026
This documentation provides some additional info about the FindInteractiveClient method that is often required for these scenarios:
https://docs.dataminer.services/develop/devguide/Automation/Howto/Launching_and_attaching_interactive_Automation_scripts.html
Bautista Solanet [SLC] [DevOps Advocate] commented 26th January 2026
In the latest version of DataMiner, the Interactivity tag was added to the script xml, setting it to Always will mean it can't be run from QActions, so use Auto
