Running Crowdstrike on DMAs and Cube client machines
Solved3.22K views6th July 2023Crowdstrike DMA
Dave Keller [DevOps Enabler]2.00K 11th March 2022 0 Comments
Our InfoSec team are requesting that we install CrowdStrike Falcon on our DMAs and Cube machines.
I can see that this question has been asked before (Crowdstrike - DataMiner Dojo), though the answer doesn't actually state what exceptions/adjustments are required to be able to run Crowdstrike.
Can anyone advise?
Dave Keller [DevOps Enabler] Selected answer as best 6th July 2023
Edson Alfaro [SLC] [DevOps Advocate]1.76K Posted 11th March 2022 0 Comments
Hi Dave,
This is the list of folder we recommend to exclude from any antivirus operation:
C:\Skyline DataMiner
C:\Program Files\Cassandra
C:\ProgramData\Cassandra
C:\ProgramData\Skyline
C:\ProgramData\Skyline Communications
C:\Skyline DataMiner Backups
D:\ProgramData [In case you have the DB data in another disk]
C:\user\AppData\Roaming\Skyline
Hope it helps.
