Running Crowdstrike on DMAs and Cube client machines
Solved3.22K views6th July 2023Crowdstrike DMA
Dave Keller [DevOps Enabler]2.00K 11th March 2022 0 Comments
Our InfoSec team are requesting that we install CrowdStrike Falcon on our DMAs and Cube machines.
I can see that this question has been asked before (Crowdstrike – DataMiner Dojo), though the answer doesn’t actually state what exceptions/adjustments are required to be able to run Crowdstrike.
Can anyone advise?
Dave Keller [DevOps Enabler] Selected answer as best 6th July 2023
Edson Alfaro [SLC] [DevOps Advocate]1.76K Posted 11th March 2022 0 Comments
Hi Dave,
This is the list of folder we recommend to exclude from any antivirus operation:
C:\Skyline DataMiner
C:\Program Files\Cassandra
C:\ProgramData\Cassandra
C:\ProgramData\Skyline
C:\ProgramData\Skyline Communications
C:\Skyline DataMiner Backups
D:\ProgramData [In case you have the DB data in another disk]
C:\user\AppData\Roaming\Skyline
Hope it helps.
Joao Candeias [SLC] [DevOps Member]141 Posted 11th March 2022 0 Comments
Hi Dave supplementing Edson’s comment please have also a look on how we detect the SL* processes interference from various antivirus applications on the link below:
https://community.dataminer.services/documentation/check-antivirus-dlls/?hilite=%27antivirus%27
CrowdStrike included.
(“BPA test is available on demand. You can run it in System Center (on the Agents > BPA tab, available from DataMiner 9.6.0 CU23, 10.0.0 CU13, 10.1.0 CU2 and 10.1.4 onwards). From DataMiner 10.1.4 onwards, it is available by default.”)
Kind regards
Joao Candeias [SLC] [DevOps Member] Answered question 11th March 2022
Jardel Costa [DevOps Advocate]278 Posted 2nd May 2023 0 Comments
About CrowdStrike AV installed on Cassandra and Elastic cluster machines using Linux Ubuntu TLS version 20.04 operating system, does anyone have experience? How to configure these exceptions?
Jardel Costa [DevOps Advocate] Answered question 2nd May 2023
