Running automation script on specified dma
Solved1.50K views2nd February 2022automation scripts
ryan yahia900 2nd February 2022 0 Comments
I am currently running an automation script which runs on all elements with a specified Protocol Name.
These elements are on different dma’s but I want to be able to run the script on the machines that the elements are running on instead of the automation script to be run on a single machine.
Is this possible?
Thanks,
Ryan
ryan yahia Selected answer as best 2nd February 2022
Miguel Obregon [SLC] [DevOps Catalyst]21.84K Posted 2nd February 2022 1 Comment
Hi Ryan,
Please check the answer for this question:
How can I execute an automation script on multiple DMA
There is a snippet that you can use to run an automation on a specific DMA.
Hope this helps.
ryan yahia Posted new comment 2nd February 2022
ryan yahia commented 2nd February 2022
Thank you!
