Router Control panel with Low-Code Apps
Solved1.09K views20th June 2023
MAXIMILIANO FILHO [DevOps Enabler]1.05K 11th April 2023 0 Comments
Hi!
Is there a way to build a router control panel using low-code apps?
Thanks in advance!
MAXIMILIANO FILHO [DevOps Enabler] Selected answer as best 20th June 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.48K Posted 14th April 2023 0 Comments
Hi Maximiliano,
DataMiner already supports building a router control using button panels. We have a use case that explains this nicely.
However, we’re actually reinventing our approach to build a router control in Low-Code Apps which is in active development. It’s already possible but requires multiple soft-launch features, so we don’t advise to use this in production yet.
Sneak peak using a table approach (note that a button approach is equally possible):
