Retrieve Owner property using automation script
Solved2.02K views15th May 2024Automation script Ownership
Pedro Sánchez [DevOps Advocate]325 8th May 2024 0 Comments
Hi Dojo!
I'm having problems to get the Owner property when using:
engine.GetAlarmProperty(alarm.DataMinerID, alarm.AlarmID, "Owner"));
I'm always getting an empty string no matter if the alarm is ack or not...
Thank you in advance!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 15th May 2024
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 10th May 2024 0 Comments
Hi Julian,
As Julian has already mentioned, the GetAlarmsProperty method can be used to retrieve custom properties. To retrieve the owner of an active alarm, the following code can be used:
var request = new GetAlarmDetailsMessage(dmaId, alarmId);
var alarm = (AlarmEventMessage)engine.SendSLNetSingleResponseMessage(request);
var owner = alarm.Owner;
