Retrieve Cassandra node IPs inside an Automation Script
487 views1st November 2025automation scripts Cassandra ips nodes
Esteban Pardo [SLC] [DevOps Member]466 31st October 2025 0 Comments
Currently, I retrieve the IP addresses of Cassandra nodes by parsing the db.xml file located in the Skyline Dataminer folder on the C: drive. However, I'm looking for a more efficient or modern method to gather this information, ideally without relying on the Apache Cassandra Driver.
Wale Oguntoyinbo [SLC] [DevOps Advocate] Answered question 1st November 2025
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.03K Posted 1st November 2025 0 Comments
One option is to have your script execute the "nodetool status" command on the Cassandra server then extract the node IPs from the output.
