Resources – what’s the different behavior between state maintenance and unavailable?
Solved1.53K views18th July 2024resources SRM
Jens Vandewalle [SLC] [DevOps Advocate]10.02K 5th February 2024 0 Comments
It's possible to put a resource in state Maintenance or Unavailable. What's the difference in behavior?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 18th July 2024
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 5th February 2024 2 Comments
Hi Jens,
I can do say the following about Maintenance mode of a resource:
- You can only put resources in Maintenance when the resource is not used by any reservation.
- It is not possible to delete a resource from the system if the mode is set on Maintenance.
This is something extra on top of Unavailable mode.
Hope this helps you further.
Jens Vandewalle [SLC] [DevOps Advocate] commented 4th June 2024
Does this mean that the logic flow is putting the resource in Unavailable mode so that it can’t be used booked anymore so that it eventually can be put in Maintenance mode?
Matthias Declerck [SLC] [DevOps Advocate] commented 18th July 2024
I’m not entirely sure on what you mean with logic flow, I do believe your customized use case. You can put resource directly in Maintenance mode if conditions are met, if that’s your question.
