Resource must be quarantined after resource swap
Solved1.31K views6th June 2024BookingManager ResourceManager SRM
Benjamin Hodžić [SLC] [DevOps Advocate]1.43K 5th June 2024 0 Comments
Hello,
I was following the instruction found here in the questions to do a resource swap mapped to a service definition node.
var assignRequest = new Library.Solutions.SRM.Model.AssignProfilesAndResources.AssignResourceRequest
TargetNodeLabel = “L-Band Matrix Input”,
NewResourceId = lBandInputResource.GUID,
When I run: serviceReservationInstance.AssignResources(engine, assignRequest);
The exception I get is the following
The resource GUID (6c77642…) provided matches the one I want to assign to the reservation.
Any suggestions on how to fix this?
Benjamin Hodžić [SLC] [DevOps Advocate] Selected answer as best 6th June 2024
Jorge Dias [SLC] [DevOps Enabler]5.36K Posted 5th June 2024 1 Comment
Hi Benjamin,
Please check if the resource you provide supports the same capabilities and/or capacities as the resource that is currently assigned in the booking.
If so, can you please share the booking log file? Will help pointing what caused the reservation to go to quarantine.
Benjamin Hodžić [SLC] [DevOps Advocate] Posted new comment 6th June 2024
Benjamin Hodžić [SLC] [DevOps Advocate] commented 6th June 2024
AssignResource was working, but overridden profile parameters needed to be initialized:
var assignRequest = new AssignResourceRequest
NewResourceId = lBandInputResource.ID,
ByReference = false,
assignRequest.OverriddenParameters.AddRange(lbandInputFunction.Parameters);
