Replication – Is it possible to access a Web Interface from a Replicated Element?
Solved3.66K views25th September 2020elements replication web interface
Bruno Nogueira [SLC]50 22nd September 2020 0 Comments
Is it possible to reach the Web Interface on a given Element card, when accessing it via a Replicated Element?
Thanks.
Bruno Nogueira [SLC] Selected answer as best 25th September 2020
Thijs Vanovenacker [SLC] [DevOps Advocate]2.71K Posted 24th September 2020 0 Comments
Note that the web interface is only accessible when the client machine has network access to the product itself.
The benefit of using replicated elements is normally to access element-data content of remote elements that are hosted on an external DMS.
So the chance that the device/system is available from the client that is connected to the system containing this replicated element is rather small.
In case it is still required, you can indeed use a custom Visio as Ben suggested to make a hyperlink or inline-webpage appear.  (Either point it to a parameter containing the IP if any, or use a property on the element to put the IP reference in.)
Thijs Vanovenacker [SLC] [DevOps Advocate] Answered question 24th September 2020
