Removing weather section
Solved2.52K views18th July 2023weather
Tiago Bento [SLC]20 10th August 2021 0 Comments
Hi Dojo Community,
Is there a way to disable the weather section in DataMiner 10.1?
Thanks in advance.
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 10th August 2021 0 Comments
More technical info:
- Weather section is a discontinued feature since 9.6.0 [CU5]. More info in RN 21592 and RN 21786.
- This was configurable with client settings. The setting is now always set to FALSE, yet it will still read the value of that setting.
You can check the user setting JSON file and search after 'Cube.homepage.enabling.weather'.
Modify the correspondent value if you need to.
