Removing invalid entries in element connections
Solved1.67K views28th January 2025
Mark Smith [DevOps Member]149 27th September 2024 0 Comments
I am using “Element Connections” to copy parameters from a polled equipment to a virtual equipment. This is working  fine.
I have recently changed the parameter id’s for a couple of parameters on that virtual element and although the new ones are working  I don’t know how to remove the old id’s.
They currently show as "Unknown_202" & "Unknown_203" on the element connections display.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th January 2025
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 24th October 2024 0 Comments
Hi Mark
Changing parameter IDs is something you should actually prevent as much as possible.
Anyway, the Cube UI will keep on saving those unlinked IDs under the assumption that the element/parameter is temporary unavailable (due to whatever reason) and that you don't want to lose those connections.
The easiest way to remove them is to change the id's back to the original ones, then unlink the element connections for the parameters you want to change via the Cube UI, and then eventually change the ids back and reconfigure the element connections. I would not mess with the files where the element connections are being stored (c:\Skyline DataMiner\Elements) as these are per Agent (based on the source element) and in a cluster this can get complicated.
Hope this helps.
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 24th October 2024
