Removing invalid entries in element connections
Solved1.65K views28th January 2025
Mark Smith [DevOps Member]149 27th September 2024 0 Comments
I am using “Element Connections” to copy parameters from a polled equipment to a virtual equipment. This is working  fine.
I have recently changed the parameter id’s for a couple of parameters on that virtual element and although the new ones are working  I don’t know how to remove the old id’s.
They currently show as “Unknown_202” & “Unknown_203” on the element connections display.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th January 2025
Mark Smith [DevOps Member]149 Posted 24th October 2024 7 Comments
Hi Pieter,
Thanks for your advice.
I know it’s not a good idea to change parameter IDs but I made a mistake when I initially entered parameter id’s which meant that they didn’t conform to the numbering scheme I had chosen for the element.
I have temporarily added back two parameters with the old id’s (202&203)
These now appear OK on the element connection screen and I can change the parameter that they are linked to. (None in the screenshot below)
However, I now want to delete the links but when I right click on the line there is a greyed out “delete” button which doesn’t seem to do anything. And clicking the left arrow doesn’t seem to do anything either.
Please can you tell me how to delete these links.
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 29th October 2024
Hi Mark,
The Delete button is only linked to removing duplicate lines (lines that have been created via the ‘Duplicate’ action in the context menu). You cannot remove the lines that were originally in the list via the delete.
In order to cleanup your element connections, the only thing you need to do is configuring the ones you want to remove with ” and then save it.
Please let me know if that indeed worked for you or not.
Mark Smith [DevOps Member] commented 29th October 2024
Hi Pieter,
Please can you explain in more detail what I need to do.
Do I change something on the element connections page or do I change something on the (virtual) parameter that I want to remove (the ones that I added by mistake on the protocol for my element).
Thanks
Mark
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 30th October 2024
Sure Mark, no problem, I’ll try to explain in more detail.
The changes I’m referring to are all to be done in the ‘Element Connections’ app in DataMiner Cube (probably where your screenshot originates from). On the first tab page ‘configure’ you have the list with all the configured connections. You’ll notice two levels of grouping in the list. Level 1 is on protocol and that should be expanded by default. Level 2 is on element and that is probably collapsed. So the first thing to do is to expand the elements for which you want to delete the element connections. Then you’ll see ‘parameter’ lines in your list with dropdown boxes in certain columns. In order to remove the connections for a certain parameter, select ” in all the dropdown boxes in that line. If you do that for all the parameters you want to remove, apply everything via the ‘Save’ button at the bottom of the list. And that’s actually all you need to do.
I hope that helps, if not, don’t hesitate to let us know. Or if you want to sync with a Teams quick call, we can set that up as well.
Mark Smith [DevOps Member] commented 30th October 2024
Hi Pieter, Can I email you direct? Thanks, Mark
sure, I’ll reach out to you so you have my contact details
Show 2 more comments
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 24th October 2024 0 Comments
Hi Mark
Changing parameter IDs is something you should actually prevent as much as possible.
Anyway, the Cube UI will keep on saving those unlinked IDs under the assumption that the element/parameter is temporary unavailable (due to whatever reason) and that you don’t want to lose those connections.
The easiest way to remove them is to change the id’s back to the original ones, then unlink the element connections for the parameters you want to change via the Cube UI, and then eventually change the ids back and reconfigure the element connections. I would not mess with the files where the element connections are being stored (c:\Skyline DataMiner\Elements) as these are per Agent (based on the source element) and in a cluster this can get complicated.
Hope this helps.
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 24th October 2024
