Regex for condition monitoring
Solved2.38K views29th June 2022alarm condition Regex
joel Joly489 24th June 2022 0 Comments
Hello DOJO
I am trying to use condition inside alarm template.
I fail to exclude/include alarm template line with regex.
The condition has to verify if the first column is : nn/empty (example ‘8/ ‘)
my regex is OK on http://regexstorm.net/tester, but doesn’t work on  template
Alarm should be Critical if Enabled and ‘nn/empty’
It works if I use “equal to” or “not equal to” but only for one line as expected
Do you think it’s a syntax problem like separator format, or misconfiguration  ?
joel Joly Selected answer as best 29th June 2022
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 24th June 2022 1 Comment
Hi Joel,
Based on DataMiner Docs (Using conditions in an alarm template), regular expressions are not supported.
From DataMiner 9.5.13 onwards, if you configure a condition based on the value of a string parameter, it is possible to use the wildcards “*” and “?”.
joel Joly commented 24th June 2022
Ah, OK, it’s my bad
Thank you Miguel
I read this documentation before asked the question, but I made a wrong shortcut, there is no mention about regex, just wildcard
