Reference SRM from Automation Script
Solved2.58K views2nd November 2022automation scipt SRM
Julio Riambau [SLC] [DevOps Member]302 28th October 2022 1 Comment
I'm referencing SLSRMLibrary.dll from an automation script.
When the dmapp is created and imported it will contain a reference to C:\Skyline DataMiner\ProtocolScripts\SLSRMLibrary.dll.
Could you please let me know which would be the procedure to correctly reference SRM in an automation script so that the dmapp contains the proper DLL reference?
Thanks in advance.
Julio Riambau [SLC] [DevOps Member] Selected answer as best 2nd November 2022
Julio Riambau [SLC] [DevOps Member] commented 31st October 2022
fixed by using the DLL Path attribute on the reference
Jens Vandewalle [SLC] [DevOps Advocate]10.07K Posted 2nd November 2022 0 Comments
Hi Julio,
In addition to the answer from Emmanuel
