Redundancy Group Element – Element Property
Solved1.50K views16th September 2024property Reundancy Group Surveor
André Kaiser [DevOps Enabler]532 23rd April 2024 1 Comment
we use the “Description” property of elements to show enhanced information behind the elements in Surveyor.
When we create a redundancy group the description of the active element of the redundancy group is assigned to the redundancy group element and shown behind it in the Surveyor. When the active element in the redundancy group changes to the backup element the redundancy group element description still show the initially assigned property value. This leads to a situation where the description property value of the main element is shown even when the redundancy group has failed over to the backup element.
Is this by design or are we missing some configuration?
Many thanks and best regards
André Kaiser [DevOps Enabler] Selected answer as best 16th September 2024
André Kaiser [DevOps Enabler] commented 5th September 2024
Is there anyone on Dojo, who may help me with this?
Thanks a lot in advance.
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 13th September 2024 0 Comments
Hi André,
Since you are referring to showing properties of elements in the surveyor, I assume you have created a ‘custom’ property with the name ‘Description’.
If you fill in a specific value for that property on all of your elements in the Redundancy Group, the virtual elements will not take over that property value. They have their own value, independent from where they link to. So Initially they should be empty. The values are being stored in the xml file on the agent in C:\Skyline DataMiner\Redundancy\yourRedundancyGroupName\Element_x_y.xml. That also means that after switching, the property values will not change on the virtual elements.
This is the default behavior I experienced and I validated this behavior on DataMiner version 10.4.8.
In case you do want to update properties, you can consider changing the redundancy mode and let DataMiner ‘intervene in the switching’ (like mentioned in the DataMiner Cube UI when going into edit mode of your Redundancy Group). With this, you can run scripts upon switching where you can for example update the properties to the correct values. I have not experimented with that yet, maybe other Dojo members have? We can definitely take a closer look at that if you would be interested to take that route.
Hope this helps.
