Read parameters for DataMiner DCF Tables
Solved2.44K views10th December 2020Dashboards DCF Visual Overview
Jan-Klaas Kesteloot [SLC] [DevOps Advocate]1.55K 10th December 2020 0 Comments
Hello everyone,
When trying to include DCF tables in a Dashboard or Visual Overview, it always gives me the possibility to perform writes.
Given the overview of the parameter IDs of the DCF tables in the DDL, do these parameters also have corresponding read parameters? If so, I could probably include these read parameters in the Dashboard or Visual Overview, preventing users to perform writes.
Jan-Klaas Kesteloot [SLC] [DevOps Advocate] Selected answer as best 10th December 2020
Jarno Lernou [SLC] [DevOps Enabler]5.95K Posted 10th December 2020 1 Comment
Hi Jan-Klaas, For the Visual Overview, you can use a so-called ParameterControlOptions DisableWritePids. It however needs the write parameters IDs (and afaik they are not exposed in Cube). For finding out the write parameter IDs you can use the Client Test tool (Advanced>Set Parameter…). I’m not sure though how this is done for Dashboards.
Jan-Klaas Kesteloot [SLC] [DevOps Advocate] commented 10th December 2020
Thanks, this worked for the Visual Overview! I added the following ParameterControlOptions in the Visual Overview
DisableWritePids:65065,65067,65090|IncludedPIDs:65096,65062,65089,65064
65065 corresponds to the [Source Interface],
65067 corresponds to the [Destination Interface],
65090 corresponds to the [Destination DataMiner/Element],
Pieter Van Compernolle [SLC] [DevOps Enabler]4.19K Posted 10th December 2020 0 Comments
Makes sense indeed to have a ‘read-only’ version of your table in dashboards. With GQI you can already get there, I believe. GQI even allows you to filter out rows and columns in an easy way.
At this moment, no alarm coloring will be applied in GQI tables, but that’s on the roadmap (currently forecasted for 10.1.4)
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 10th December 2020
