Read and update View Property through automation script
Solved2.22K views29th March 2024Automation view properties
Michael Kotsias [DevOps Advocate]168 25th March 2024 2 Comments
Dear dojo,
I'm creating an automation script where i read a view Property through
IDms dms = engine.GetDms();
IDmsView myView = dms.GetView(Convert.ToInt16( viewid ));
IDmsViewProperty myViewProperty = myView.Properties.SingleOrDefault(x => x.Definition.Name == "myPropertyName");
This part is fine but when i try to update the Value with
myViewProperty.Value = "new value";
i get the message "myViewProperty.Value cannot be assigned to -- it is read only"
I'm able to assign a value manually. So i don't understand why this property should be read only.
Is there a way to manipulate this?
Thanks
Michael Kotsias [DevOps Advocate] Posted new comment 29th March 2024
Tom Waterbley [SLC] [DevOps Enabler] commented 29th March 2024
Hi Michael. Based on this question and other feedback, we decided to make setting properties on elements, services and views a bit more intuitive. The property object now contain IsWritable and AsWritable methods, which replace the cast to IWritableProperty. This has been implemented in version 1.1.1.8 of the DMS library.
Michael Kotsias [DevOps Advocate] commented 29th March 2024
Hi Tom,
Cool! This makes sense. Thank you for information.
Tom Waterbley [SLC] [DevOps Enabler]10.21K Posted 25th March 2024 0 Comments
Hi Michael,
This example shows how to update properties of an element. A similar approach can be used to update properties of views: https://docs.dataminer.services/develop/devguide/ClassLibrary/ClassLibraryExamples.html#setting-a-property-and-renaming-the-element.
The trick is to first cast the property to IWritableProperty.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 26th March 2024
