Read a property into a session variable when a card with a Visio is opened
Solved1.65K views29th November 2024property SessionVariable visio properties
Dominik Kosteletzky [DevOps Advocate]773 29th November 2024 0 Comments
Hi guys,
I tried an execute:
Set|Variable|ID|[Param:17/1815,65022:StoredID]|SetTrigger=Event
A stored property StoredID should be read into a variable ID.
This is on the page level and Options ExecuteSetsOnInit is set too.
This give me a loading screen. Wrong Syntax?
Dominik Kosteletzky [DevOps Advocate] Answered question 29th November 2024
Dominik Kosteletzky [DevOps Advocate]773 Posted 29th November 2024 0 Comments
Just to conclude this. The Syntax is:
Set|Variable|ID|[Param:17/1815,65022,StoredID]|SetTrigger=ValueChanged
...and also important is that this is also on the page level with Options ExecuteSetsOnInit.
Dominik Kosteletzky [DevOps Advocate] Changed status to publish 29th November 2024
