Read a property into a session variable when a card with a Visio is opened
Solved1.73K views29th November 2024property SessionVariable visio properties
Dominik Kosteletzky [DevOps Advocate]773 29th November 2024 0 Comments
Hi guys,
I tried an execute:
Set|Variable|ID|[Param:17/1815,65022:StoredID]|SetTrigger=Event
A stored property StoredID should be read into a variable ID.
This is on the page level and Options ExecuteSetsOnInit is set too.
This give me a loading screen. Wrong Syntax?
Dominik Kosteletzky [DevOps Advocate] Answered question 29th November 2024
Klaas Dewitte [SLC] [DevOps Advocate]952 Posted 29th November 2024 2 Comments
The syntax for the param placeholder is:
[param:DmaID/ElementID,ParameterID,TableRow] (mark the , instead of : for tablerow)
If the row is stored in a property called StoredID, you will have to wrap that in another placeholder:
Set|Variable|ID|[Param:17/1815,65022, [property:StoredID]]|SetTrigger=valuechanged
If the goal is to have the variable update when the param update, you will also need to use SetTrigger=valuechanged
Dominik Kosteletzky [DevOps Advocate] Selected answer as best 29th November 2024
Dominik Kosteletzky [DevOps Advocate] commented 29th November 2024
Hi Klaas, it cannot work, as parameter ID 65022 is already the property and I cannot use the [porperty:] allone as on the page level I cannot define then which element it is.
Klaas Dewitte [SLC] [DevOps Advocate] commented 29th November 2024
Im not fully following where the data is from, what does your table look like that you are getting the value from. If StoredID is your table row id, then it should done without the property placeholder indeed
Dominik Kosteletzky [DevOps Advocate]773 Posted 29th November 2024 0 Comments
Just to conclude this. The Syntax is:
Set|Variable|ID|[Param:17/1815,65022,StoredID]|SetTrigger=ValueChanged
…and also important is that this is also on the page level with Options ExecuteSetsOnInit.
Dominik Kosteletzky [DevOps Advocate] Changed status to publish 29th November 2024
