R-click menu: keep “Protocols & Templates” listed when the selected elements use the same protocol?
Solved1.87K views29th October 2021Admin Tasks Cube elements Protocols & Templates View Card
Alberto De Luca [DevOps Enabler]5.36K 27th October 2021 0 Comments
in a View Card/Elements>R-click menu, is it possible to keep the "Protocols & Templates" listed when the selected elements use the same protocol?
In v.9 I have "protocol & templates" only if I select one single element: when selecting two elemeents (even if relying on the same protocol) the Protocols & Templates section is removed.
This would help when quickly patching just a couple of elements found through a view.
I'm used to go to "Protocols & Templates">SelectProtocol>"Assign Alarm Template" then select elements, but this is a bit of overkill for just a couple of elements that I have alredy on the screen, just looking for a way to save time - what's the expected behaviour in DM10?
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 27th October 2021
Matthias Declerck [SLC] [DevOps Advocate]2.99K Posted 27th October 2021 1 Comment
Hi Alberto,
For your request: this would be a nice-to-have feature.
For your use-case: you can select the 'view available templates', which opens the selected protocol + version in the P&T module.
From there, you can manage the templates for the elements with the 'assign elements' button.
Screenshot:
Matthias Declerck [SLC] [DevOps Advocate] Answered question 27th October 2021
Alberto De Luca commented 27th October 2021
Thanks Matthias,
I do this too, but I have to jot down the names for the specific elements I wanted to select in the view – the filter in the “assign elements” pop-up doesn’t give me any info on the view where the elements are added – as said this is because I tend to start most of my checks for project delivery directly from the related view.
