Protocol – Connecting to a data source using application/x-www-form-urlencoded in header
Solved1.68K views10th January 2022protocol urlencoding
Ian Harvey [SLC] [DevOps Member]844 10th January 2022 0 Comments
I'm looking to add 'application/x-www-form-urlencoded' in the request header to be sent from a protocol. Can anyone provide an example of how this can be achieved using a DataMiner Protocol.
NOTE: Only some POST commands require URLENCODING. The majority of GET/PUT/DELETE commands can be sent without the additional header.
DEVICE API INFORMATION
For POST APIs, ensure that the following conditions are met:
  • Content type must be set to application/x-www-form-urlencoded in request header
  • Request body must be URL encoded
Ian Harvey [SLC] [DevOps Member] Selected answer as best 10th January 2022
Jens Vandewalle [SLC] [DevOps Advocate]10.00K Posted 10th January 2022 2 Comments
Hi Ian,
Below an example that should work:
Christopher Washburn Posted new comment 27th August 2024
Ian Harvey [SLC] [DevOps Member] commented 10th January 2022
Many thanks Jens. This solution works perfectly.
Christopher Washburn commented 27th August 2024
I would love to see what parameter 103 “Login Request Body” might look like as an example if that would be possible to share.
