Protocol CheckTrigger from an automation script
Solved1.92K views11th April 2023Automation script
Philip Argent [DevOps Advocate]1.13K 28th November 2022 0 Comments
I'm writing an user interactive automation script to set two settings on equipment an element is connected to. Usually I would just set the two parameters, but the protocol currently has a bug where other values are set incorrectly, and the values can be sent in one API message body, instead of two separate messages, where the the first value will sometimes get overwritten by the second set, as the read value of the first hasn't updated yet.
The QAction in the protocol sets two parameters for a session, one for the body and one for the URI, then does a CheckTrigger to send the http PUT.
Following the same in my automation script I'll lock the element during the process (so nothing else updates the two common session parameters), set the two parameters, and then I want to fire off the same Trigger, save modifying the protocol to add a dummy parameter with a separate Trigger to do the same thing; is there a was of doing this outside of an element?
Tom Waterbley [SLC] [DevOps Enabler] Answered question 28th November 2022
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 28th November 2022 1 Comment
Hi Philip, as far as I know there is no way to execute CheckTrigger from outside the protocol itself. As a temporary solution, until a better fix is available, you could maybe add a dummy parameter to the protocol, that triggers the HTTP PUT.
Philip Argent commented 28th November 2022
Thanks Tom,
That’s what I’m currently doing, I was just hoping to avoid modifying the protocol, as it’s a Skyline supplied one.
