Profile Load Script – Take a write lock on an element
Solved2.10K views27th February 2023Automation automation scripts profile load script SRM
10
Jochen Dewachter [SLC] [DevOps Member]2.17K 24th February 2023 0 Comments
We have multiple automation scripts (SRM Profile Load Scripts) that are trying to set the same parameters on the same element at the same time which causes troubles.
Currently we're using this as locking mechanism:
private static ConcurrentDictionary<string, object> lockDictionary = new ConcurrentDictionary<string, object>();
var lockObject = lockDictionary.GetOrAdd(mainElementId, (key) => new object());
lock (lockObject)
//do your sets
However this only works within the same SLAutomation process => if the scripts are running from the same DMA. In case of a cluster environment, how can I make sure that profile load scripts that are running on different DMAs are waiting for each other before making sets to the element?
Tom Waterbley [SLC] [DevOps Enabler] Answered question 27th February 2023
Tom Waterbley [SLC] [DevOps Enabler]10.01K Posted 27th February 2023 0 Comments
Didn't test this yet, but another approach that might work is to let the script lock the elements it needs. Probably you'll need to call another subscript with the elements as input.
