Profile Load Script – Take a write lock on an element
Solved2.87K views27th February 2023Automation automation scripts profile load script SRM
10
Jochen Dewachter [SLC] [DevOps Member]2.17K 24th February 2023 0 Comments
We have multiple automation scripts (SRM Profile Load Scripts) that are trying to set the same parameters on the same element at the same time which causes troubles.
Currently we're using this as locking mechanism:
private static ConcurrentDictionary<string, object> lockDictionary = new ConcurrentDictionary<string, object>();
var lockObject = lockDictionary.GetOrAdd(mainElementId, (key) => new object());
lock (lockObject)
//do your sets
However this only works within the same SLAutomation process => if the scripts are running from the same DMA. In case of a cluster environment, how can I make sure that profile load scripts that are running on different DMAs are waiting for each other before making sets to the element?
Tom Waterbley [SLC] [DevOps Enabler] Answered question 27th February 2023
Jens Vandewalle [SLC] [DevOps Advocate]10.09K Posted 24th February 2023 3 Comments
Hi Jochen,
I guess you can resolve this by using Mutex for your locking.
Tom Waterbley [SLC] [DevOps Enabler] Posted new comment 27th February 2023
Tom Waterbley [SLC] [DevOps Enabler] commented 27th February 2023
Hi Jens. A mutex can be used for inter-process communication on the same machine. This doesn’t work when the processes are running on different machines as in this case.
Jens Vandewalle [SLC] [DevOps Advocate] commented 27th February 2023
Hi Tom, I wasn’t aware of that. Is there something else that can be used instead?
Not out of the box. For locking that works over multiple machines, something that manages those locks will be needed (i.e. database, element, …). Clients connect to that manager to acquire and release the lock.
  • What’s new in DataMiner 10.6.10?
  • What’s new in DataMiner 10.6.9?
