Problems logging in to ziine
Solved1.87K views5th October 2022ziine
Edith Lansens [SLC] [DevOps Member]789 5th October 2022 0 Comments
I'm having trouble logging in to ziine. When I enter my username and password, I get an error. Does anyone know how to fix this?
Bert Buysschaert [SLC] [DevOps Advocate] Answered question 5th October 2022
Bert Buysschaert [SLC] [DevOps Advocate]5.06K Posted 5th October 2022 0 Comments
A new Cube version with a fix has just been published on the preview track. If you don't want to wait until the next automatic update check, you can fetch it with a manual "Check for updates" via the bottom-right menu of the Cube Start Window.
