Problem when using [Property:] in vdxpage shape data
Solved2.33K views1st February 2022placeholder property shape data Visual Overview
Jeroen Nietvelt [SLC] [DevOps Member]1.39K 31st January 2022 0 Comments
The [property:] placeholder doesn’t appear to resolve when using it inside a vdxpage shape data as defined in the below example:
Any suggestion towards how i can get this to work?
The reason for this kind of setup is that this visio will be assigned to a protocol which is then loaded by all elements making use of this exact protocol. However each of the elements require a slightly different visual overview. By linking it to a specific dedicated visual overview page on view level, i can automatically load (by referencing to element specific property values) different visual overview pages.
If there would be an alternative approach that gets me to the same outcome, I would be very happy to learn about that….
Jeroen Nietvelt [SLC] [DevOps Member] Selected answer as best 1st February 2022
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 1st February 2022 2 Comments
Does the property ‘VisualOverviewLink‘ and ‘VdxPage‘ live on the same object? Or do you want to fetch the property ‘VdxPage‘ from the object to which the ‘VisualOverviewLink‘ property points to?
If it’s the latter, you’ll need to make the ‘VdxPage‘ a child shape of the view, so that it retrieves the value from the parent instead of from the object to which the Visual Overview is assigned.
Edit:
I could reproduce this behavior and it doesn’t seem intentional. I’ll notify the people working on this so it can be investigated.
In any case, you can work around this issue by adding the ‘ForcePropertyFromPage‘ option to your shape.
Jeroen Nietvelt [SLC] [DevOps Member] commented 1st February 2022
Hi Sebastiaan, In our case we have both properties living on the same element object which is also the object to which the visio file is attached to (protocol visio file) I can also confirm that the [property:VisualOverviewLink] placeholder resolves fine in the View shape data.
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 1st February 2022
Alright, thanks for the info. I’ve edited my answer.
