Problem using [Property:..] in InitVar
Solved1.86K views1st February 2022Custom property Visio Visual Overview
Robin Becker [DevOps Member]1.42K 31st January 2022 0 Comments
I don’t know if it’s only on our end but I can’t seem to initialize variables with values containing the [Property:..]-placeholder in my visual overview.
Is it only on our end or a common bug?
Robin Becker [DevOps Member] Selected answer as best 1st February 2022
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 31st January 2022 0 Comments
This is not a bug but rather a natural consequence of how a Visual Overview is initialized. InitVar shape data is processed synchronously with the creation of your Visual Overview.
Meanwhile placeholders such as the property placeholder require us to do a request to the server. Because we don’t want to be blocked until the server responds, we do this asynchronously.
The consequence is that InitVar can’t use the property placeholder properly, as it doesn’t have the value yet.
You can work around this by using the Execute shape data, along with the ExecuteSetsOnInit option (in the options shape data) and the ValueChanged trigger. More info can be found on our help pages
