Problem restarting Cassandra node
Solved1.81K views27th April 2025CassandraCluster CassandraDB
Matthew Smith70 12th February 2025 0 Comments
Dear Dojo community,
We have been running a cluster of 3 Cassandra nodes (running under Linux) for several months now and we recently hit a problem with one of the nodes where the /var directory ran out of disk space and crashed the Cassandra process. We cleared out some of the temp files in this directory and then restarted the VM. Afterwards we found that Cassandra would not restart and in the system.log file we find the error "CassandraDaemon.java:808 - Cannot start node if snitch's data center (dc1) differs from the previous data center (datacenter). Please fix the snitch configuration, decommission and rebootstrap this node or use the flag -Dcassandra.ignore_dc=true"
Our cassandra.yaml file has not been changed (file date from last year) and so we are confused why this is an issue? We are reluctant to start changing the configuration unless necessary and so any insight into the problem would be much appreciated.
Best regards,
Matt
Arunkrishna Shreeder [SLC] [DevOps Enabler] Selected answer as best 27th April 2025
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.36K Posted 13th February 2025 0 Comments
Hi Matt,
Can you share the value of endpoint_snitch in the cassandra.yaml file ?
Depending on it, you can try the options mentioned in these links :
https://stackoverflow.com/questions/38961502/cannot-start-node-if-snitchs-data-center-differs-from-previous-data-cente
CassandraDaemon.java:731 – Cannot start node if snitch’s data center (dc1) differs from previous data center (datacenter1)
