Problem initializing parameters in menu GENERAL PARAMETERS ( Framework Connectivity)
Solved2.27K views23rd January 2024
Jaroslaw Burtny [DevOps Member]756 18th January 2024 0 Comments
Hi All.
The problem with DCF connection in dashboards is probably because I cannot initiate connections in menu GENERAL PARAMETERS ( Framework Connectivity)  for Element AppearTV X10 and BridgeTech VB 2220 as below
But in Element TMux Ateme I see these connection as below :
How can I takes these parameters from Menu GENERAL PARAMETERS --> Framework Connectivity correctly on DMA and next to dashboard for DCF connection.
Are these parameters initialized automatically by the driver or can I set them?
I see them not initialized for some elements
Is it a problem with  the driver? something needs to be marked in driver or a bad driver for elements?
Big thanks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 23rd January 2024
Jaroslaw Burtny [DevOps Member]756 Posted 19th January 2024 2 Comments
Hi Joao.
I configured the connections manually as below.
External connection TMUX --> AppearTV  FROm TMUX site:
External connection APPEARTV --> TMUX  FROm APPEARTV site
It seems that everything is fine due to external connections..
I can't display garf connections between nodes, still
below are my settings for DCF connection
It seems OK but I can't see the graphical connection between the nodes
Where could the problem be?
Big thanks for help,
Br.
Jarek
Jaroslaw Burtny [DevOps Member] Posted new comment 19th January 2024
João Severino [SLC] [DevOps Enabler] commented 19th January 2024
At first glance, everything seems to be correct but maybe someone with more experience in the Node Edge Graph can provide input on this.
Jaroslaw Burtny [DevOps Member] commented 19th January 2024
Br.
Jarek
