Problem configuring parameters in the driver
Solved2.03K views1st February 2024
Jaroslaw Burtny [DevOps Member]756 17th December 2023 0 Comments
Hi All.
I have a problem when modifying the driver.
Let's assume we have two parameters.
- param1 (takes values from 1 to 100), read from the device via snmp
- param2 (takes values 0, 1), read from the device via snmp
I would like param1 to take negative values when param2 = 1 (param1 = from -1 to -100) and positive values when param2 = 0 (param1 = from 1 to 100)
It seems like a simple thing, but I can't do it by trigger (change) - action on the param1 parameter and multiply by -1 with param2 = 1 because it will create an infinite loop
I can't do it using QAction for param1 as a trigger, because protocol.SetParameter on param1, because it also loops.
Thanks for any reply 🙂
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 1st February 2024
frans siew [SLC] [DevOps Advocate]1.08K Posted 18th December 2023 0 Comments
Hi Jaroslow,
if there is no writes done on to the device, I would recommend using param3 and setting the value on that parameter. And to turn param1 into a 'hidden' parameter.
In this case a infinite loop can be avoided and done by either methods that you have tried.
