Preprocessor #defineon a C# automation script
Solved1.54K views19th July 2023
Henri Martins [DevOps Advocate]906 28th June 2023 0 Comments
Hi.
I want to use preprocessor instruction "#define DEBUG" as first instruction on a C# automation script
But when I clic validate, I've got one error: "Cannot define/undefine preprocessor symbols after token in file".
I don't understand what is the problem. What is the token, it's talking about?
Better how could I resolve it without running allways instructions like I've seen in others questions on DOJO.
Thanks
Tom Van Bruaene [SLC] [DevOps Member]913 Posted 28th June 2023 0 Comments
See: Adding C# code to an Automation script | DataMiner Docs
If you don't define a Script class, dataminer will make that class for you and wrap your code in it.
#define is not allowed to be in a class in C# so it will give that error.
So if you want to work with defines you should write your own script class and run your code in the Run method.
