Post Upgrade actions required?
Solved2.26K views19th July 2023upgrade upgrades
Jeff Douglass870 5th January 2021 0 Comments
After upgrading DM to a new version, such as 9.6 CU10 -> CU20 or 9.5->9.6, what additional steps are required? for example:
  1. For IE Cube clients, clear the IE and XBAP cache on all client machines
  2. For Standalone Cube Client, download the latest client from the DMA after the upgrade
  3. Is it ever required to reboot the actual DMA server, say when upgrading major versions such as 9.6->9.6 or 9.6->10.0
Thanks
Karel Lodefier [SLC] [DevOps Member]724 Posted 6th January 2021 0 Comments
Hi Jeff, first of all my best wishes for 2021!
After a DMA upgrade it's indeed important to update the DataMiner client:
  1. For IE Cube clients: a refresh in IE should automatically trigger the download of the new Cube client version. If there would be a problem, then indeed clearing the XBAP cache can resolve this.
  2. For Standalone Cube client: correct, you'll need to download the new version linked to your installed/upgraded DataMiner version.
Related to the DataMiner server itself:
3. No server reboot is required after a DMA upgrade.
In general, I would recommend to move to our latest & greatest Cube launcher (compatible with all supported DataMiner versions). The Cube launcher is available on DataMiner Services (right top: Install DataMiner Cube). On this you can add any DataMiner agent (running same or different DataMiner versions). When upgrading a DMA, the launcher will automatically detect the new client version, so no manual action is required (anymore). More information is available on:
  • Internet Explorer Support – DataMiner Dojo
  • DataMiner Cube launcher updates – DataMiner Dojo
  • Cube Launcher – DataMiner Dojo
