POST Request does not behave as it should
Solved1.94K views12th July 2023AWS HTTPS post SLPort
Miguel Guevara [DevOps Member]307 9th November 2022 0 Comments
I made a POST request using Postman and I tried to make the same request using DataMiner 10.2.8 but the results are different.
In DM, I am using the following element configuration and implementation:
And these are the vales for the PIDs used in this session:
This results in a "404 Not found" response. Which should be alright if I was missing a header, or if it was not a POST request.
Finally, when I send the same request using Postman I get a different error, "400 Bad Request". This error is understandable because is being process by AWS but it realizes that the "Signature Expired":
What could I be doing wrong in the implementation (I've tried many things)?
Is there a way see the complete request how it is sent before leaving DataMiner?
Please and thank you!
Julio Riambau [SLC] [DevOps Member]302 Posted 10th November 2022 0 Comments
Hi Miguel,
Could you please try to use one of the AWS protocols as reference?
Example session form MediaConnect
<Session id="3" name="Start Stop Flow" ignoreTimeout="true">
<Connection id="1">
<Request verb="POST" pid="253">
<Headers>
<Header key="Host" pid="14"></Header>
<!-- SuppressValidator 8.3.1 Header used in AWS request -->
<Header key="X-Amz-Algorithm">AWS4-HMAC-SHA256</Header>
<!-- /SuppressValidator 8.3.1 -->
<Header key="X-Amz-Date" pid="15"></Header>
<Header key="Authorization" pid="12"></Header>
<Header key="Content-Type">application/json</Header>
<Header key="Accept">application/json</Header>
<Header key="Content-Encoding">amz-1.0</Header>
</Headers>
</Request>
<Response statusCode="103">
<Content pid="153" />
</Response>
</Connection>
</Session>
I hope it can be helpful.
Best regards,
