POST HTTP request protocol no response – element goes into timeout
Solved3.38K views25th March 2024
11
Zhing Hang Lee672 18th March 2024 2 Comments
Hi, I am creating a protocol with HTTP POST request. I followed every instructions provided and looked through a lot of examples but still my protocol does not work.
Here's what I did:
  • created a protocol with type http
  • I specified the port settings
  • Then I start creating the flow until it reaches the session. Timer > Group > Session
  • In my POST session, I am consuming the authorization token as a form of header from a parameter which user can change. The same goes for the SQL statement, warehouseID, wait_timeout and on_wait_timeout information which if I understood correctly will be parse in the body as a form of JSON.
  • Next I have defined paramaters that hold the response status code and content.
  • The paramater content 107 is then linked to a QAction which will perform the data parsing.
Then I create a new element with this protocol and I configure all the details needed. I also specified the IP address of which the url destination I am consuming from.
What I expect is that the call is to be made successful and QAction is being called. But after I set the values nothing is happeing. The QAction is not being executed and status code is not showing the result such as 200ok and now the element goes into timeout immediately.
May I know what is the problem here? I followed every step I know but nothing is working.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 25th March 2024
Robbie Demaegdt [SLC] [DevOps Member] commented 18th March 2024
Can you check with streamviewer on the element what the communication looks like.
Zhing Hang Lee commented 19th March 2024
Hi Robbie,
Thank you for the quick response. I have checked the stream viewer as you mentioned and there seems to be a request timeout.
-> 15:28:12 – Error : 12002. [ERROR_WINHTTP_TIMEOUT]
-> 15:28:12 – Get for ResponseContent () had error : Error : 12002. [ERROR_WINHTTP_TIMEOUT]
-> 15:28:12 – Continuing get for ResponseContent ()
Do you know what this means? I used the bypassProxy in the bus address and also specified an IP address in the protocol paramater proxyServer.
Sebastián Cuéllar [SLC] [DevOps Advocate]266 Posted 20th March 2024 0 Comments
Hello Lee,
Following the advices that Robbie and Daniela gave you, I would recommend you the following:
  1. Download and test the request with the Postman Desktop App.
    1. Be sure that the HTTPS port (443) that you are using to establish the communication is correct.
    2. Be sure that the HTTP method you are using is correct (GET, POST, PUT, etc.)
    3. Be sure that the JSON data content is in the proper format.
  2. If the process succeeds in Postman, the same configuration should work for Dataminer and the Error : 12002. [ERROR_WINHTTP_TIMEOUT] should disappear as this typically means that the URL is not reachable.
    1. If the error persists, you could try to increase the value of the timeout in the element settings to the max (120000 if I'm not mistaken).
  3. As Daniela suggested, the best approach to built the data content of the request is through a QAction and saving it in a parameter.
  4. You should trigger the Session execution after the QAction.
Let me know if you manage to solve the problem following these steps.
Sebastián Cuéllar [SLC] [DevOps Advocate] Answered question 20th March 2024
