Possible causes of GetParameter 0x80004005 fail in automation scripts?
Solved3.15K views12th December 2022Automation
Tom Waterbley [SLC] [DevOps Enabler]10.36K 25th August 2020 0 Comments
In an automation script we already had a few times that a GetParameter call failed with error code: 0x80004005
Get Parameter ('_22818_1':530/) Failed: 0x80004005
We cannot reproduce the issue (only happens a few times a month), and couldn't find the root cause. All agents and elements were active. No strange things could be found in the information events, except that the GetParameter has failed.
What are the possible causes for error code 0x80004005? Can this occur when something happens during network communication between the two DMAs?
Tom Waterbley [SLC] [DevOps Enabler] Selected answer as best 12th December 2022
Robin Devos [SLC] [DevOps Advocate]3.01K Posted 27th August 2020 0 Comments
0x80004005 is a very generic error code, it might as well say "computer says no", without any additional explanation.
Not sure about it, but I would think 1 of the involved SL processes was blocked or frozen for a second. If this is the case, then it won't be easy to investigate.
Possible ways to move forward:
  • If allowed, increase log level to 5, but note that some SL* log files could get overwritten quickly (ie SLNet).
  • If this is critical, then you could also try to add a try-catch on that GetParameter, if it fails, then take the memdumps + pendingCalls for that element. (We already have scripts for this, but might need some changes)
