Possible causes of GetParameter 0x80004005 fail in automation scripts?
Solved2.93K views12th December 2022Automation
Tom Waterbley [SLC] [DevOps Enabler]10.29K 25th August 2020 0 Comments
In an automation script we already had a few times that a GetParameter call failed with error code: 0x80004005
Get Parameter ('_22818_1':530/) Failed: 0x80004005
We cannot reproduce the issue (only happens a few times a month), and couldn't find the root cause. All agents and elements were active. No strange things could be found in the information events, except that the GetParameter has failed.
What are the possible causes for error code 0x80004005? Can this occur when something happens during network communication between the two DMAs?
Tom Waterbley [SLC] [DevOps Enabler] Selected answer as best 12th December 2022
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 26th August 2020 1 Comment
Hi Tom,
Is it possible that you try to get a table parameter without specifying a valid index?
Tom Waterbley [SLC] [DevOps Enabler] Posted new comment 26th August 2020
Tom Waterbley [SLC] [DevOps Enabler] commented 26th August 2020
No it’s a standalone parameter and all IDs are correct. Right before and after the get that fails, other gets on the same parameter succeed.
