Possibility to customize “right click menu” in the active alarm console
Solved1.34K views14th April 2025AutomtionScript script from alarm console
Jurica Gajski176 14th April 2025 0 Comments
Dear,
Is it possible to customize (enhance) Dataminer “right click menu” in the active alarm console? For example if we want to add menu for sending e-mails. Right click with mouse on selected active alarm should open enhanced menu with new menu “send email script” like is already possible with installed option “Send by SMS…”
Thank you!
Jurica Gajski Selected answer as best 14th April 2025
Miguel Obregon [SLC] [DevOps Catalyst]23.97K Posted 14th April 2025 1 Comment
Hi Jurica,
I believe this can be achieved with hyperlinks.
Hope it helps.
Jurica Gajski commented 14th April 2025
Yes, it helps. Thank you!
