Ports required to allow Dataminer to work properly
Solved1.45K views17th July 2023
Edgar Roca 30th December 2021 0 Comments
Hi team , right now our dataminer cluster have the windows firewall inactive , we got the request to activate the windows firewall on every dma server, wich ports range is required to avoid issues with the current configuration we have on our cluster?
Jamie Stutz [SLC] [DevOps Member]1.18K Posted 30th December 2021 0 Comments
Hi Edgar,
The answer depends on a few things including your DM version and what options you have configured for your cluster. There's a great blog post about securing DataMiner that goes into great detail about ports and I think you'll find what you need here: Securing DataMiner | Part 2: Firewall - DataMiner Dojo.
You can also check out the DataMiner Help - General DMA Configuration. Click on the "Configuring the IP network Ports" link at the top of the page.
Good luck and let us know if you have more specific questions!
-J
