Port number for backing up to network path
Solved490 views28th August 2025backup port
paul farndell [DevOps Advocate]712 27th August 2025 0 Comments
Hi, can you confirm which port is used when backing up to a network path? I'm assuming it is port 20 FTP?
paul farndell [DevOps Advocate] Selected answer as best 28th August 2025
Bert Vandenberghe [SLC] [DevOps Enabler]9.75K Posted 27th August 2025 1 Comment
Hi Paul,
The backup to a network path is using SMB. You can find this is a small note in our documentation: Backing up a DataMiner Agent in DataMiner Cube | DataMiner Docs
SMB is using TCP port 445 (and 139 for older versions).
Bert
paul farndell [DevOps Advocate] Posted new comment 28th August 2025
paul farndell [DevOps Advocate] commented 28th August 2025
Thanks, I will go and beg the Firewall police to open that port:-)
