Permission errors on automation scripts
Solved2.20K views10th February 2022
ryan yahia900 10th February 2022 0 Comments
I am testing an automation script out where it upgrades the versions of elements but get this error when running the script:
I have admin permissions and have successfully ran it on other environments. Is there any settings which I have to include to be able to run this script?
Thanks,
Ryan
Warning
ServerTime: 10/02/2022 12:28:40
ClientTime: 10/02/2022 12:28:41
Message : Automation script 'UpgradeVersions' failed to execute.
Exception: The script failed to execute.
(Code: 0x800402CC) Skyline.DataMiner.Net.Exceptions.DataMinerCOMException: You don't have permission to perform this action.
---> System.Runtime.InteropServices.COMException: Exception from HRESULT: 0x800402CC
Server stack trace:
at Interop.SLDataMiner.IDataMiner.NotifyDataMiner(String bstrUser, Int32 iType, Object varValue, Object varValue2, Object& pvarReturnValue)
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Skyline.DataMiner.Net.MessageHandler.HandleAddUpdateElement(IConnectionInfo connInfo, AddElementMessage aem)
at Skyline.DataMiner.Net.Facade.HandleClientRequestMessage(IConnectionInfo connInfo, ClientRequestMessage oneMsg, Boolean canQueue)
at Skyline.DataMiner.Net.Facade.HandleMessageInternal(IConnectionInfo connInfo, DMSMessage oneMsg, Int32 groupID, Int32 groupTotal)
at Skyline.DataMiner.Net.Facade.HandleMessage(IConnectionInfo connInfo, DMSMessage oneMsg, Int32 groupID, Int32 groupTotal)
at Skyline.DataMiner.Net.BaseFacade.HandleMessages(IConnectionInfo connInfo, DMSMessage[] msgs)
at Skyline.DataMiner.Net.Facade.HandleImpersonateMessage(IConnectionInfo originalConnInfo, ImpersonateMessage im)
at Skyline.DataMiner.Net.Facade.HandleMessagesForClient(IConnectionInfo connInfo, DMSMessage[] messages)
at Skyline.DataMiner.Net.Transport.Remoting.InternalHandleMessages(ConnectionToken token, DMSMessage[] inputMessages)
Server stack trace:
at Skyline.DataMiner.Net.Transport.Remoting.HandleMessages(ConnectionToken token, DMSMessage[] inputMessages)
at CManagedAutomation.RunWrapped(CManagedAutomation* , Int32 iCookie, IUnknown* pIAutomation, tagVARIANT* varParameters, tagVARIANT* pvarReturn, String scriptName)
at CManagedAutomation.Run(CManagedAutomation* , Int32 iCookie, Char* bstrScriptName, IUnknown* pIAutomation, tagVARIANT* varParameters, tagVARIANT* varEntryPoint, tagVARIANT* pvarReturn) (CSharp; 0x800402cch):
ryan yahia Selected answer as best 10th February 2022
Pedro Almeida [SLC]296 Posted 10th February 2022 0 Comments
Hello Ryan,
The issue was on a call of the script itself that was not present on the first system.
