Permission errors on automation scripts
Solved1.70K views10th February 2022
ryan yahia900 10th February 2022 0 Comments
I am testing an automation script out where it upgrades the versions of elements but get this error when running the script:
I have admin permissions and have successfully ran it on other environments. Is there any settings which I have to include to be able to run this script?
Thanks,
Ryan
Warning
ServerTime: 10/02/2022 12:28:40
ClientTime: 10/02/2022 12:28:41
Message : Automation script 'UpgradeVersions' failed to execute.
Exception: The script failed to execute.
(Code: 0x800402CC) Skyline.DataMiner.Net.Exceptions.DataMinerCOMException: You don't have permission to perform this action.
---> System.Runtime.InteropServices.COMException: Exception from HRESULT: 0x800402CC
Server stack trace:
at Interop.SLDataMiner.IDataMiner.NotifyDataMiner(String bstrUser, Int32 iType, Object varValue, Object varValue2, Object& pvarReturnValue)
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Skyline.DataMiner.Net.MessageHandler.HandleAddUpdateElement(IConnectionInfo connInfo, AddElementMessage aem)
at Skyline.DataMiner.Net.Facade.HandleClientRequestMessage(IConnectionInfo connInfo, ClientRequestMessage oneMsg, Boolean canQueue)
at Skyline.DataMiner.Net.Facade.HandleMessageInternal(IConnectionInfo connInfo, DMSMessage oneMsg, Int32 groupID, Int32 groupTotal)
at Skyline.DataMiner.Net.Facade.HandleMessage(IConnectionInfo connInfo, DMSMessage oneMsg, Int32 groupID, Int32 groupTotal)
at Skyline.DataMiner.Net.BaseFacade.HandleMessages(IConnectionInfo connInfo, DMSMessage[] msgs)
at Skyline.DataMiner.Net.Facade.HandleImpersonateMessage(IConnectionInfo originalConnInfo, ImpersonateMessage im)
at Skyline.DataMiner.Net.Facade.HandleMessagesForClient(IConnectionInfo connInfo, DMSMessage[] messages)
at Skyline.DataMiner.Net.Transport.Remoting.InternalHandleMessages(ConnectionToken token, DMSMessage[] inputMessages)
Server stack trace:
at Skyline.DataMiner.Net.Transport.Remoting.HandleMessages(ConnectionToken token, DMSMessage[] inputMessages)
at CManagedAutomation.RunWrapped(CManagedAutomation* , Int32 iCookie, IUnknown* pIAutomation, tagVARIANT* varParameters, tagVARIANT* pvarReturn, String scriptName)
at CManagedAutomation.Run(CManagedAutomation* , Int32 iCookie, Char* bstrScriptName, IUnknown* pIAutomation, tagVARIANT* varParameters, tagVARIANT* varEntryPoint, tagVARIANT* pvarReturn) (CSharp; 0x800402cch):
ryan yahia Selected answer as best 10th February 2022
Gellynck Jens [SLC]2.71K Posted 10th February 2022 1 Comment
Hi Ryan,
Recently a bug was fixed that could cause this behavior on server 2016, see release note 32035. This should be addressed from DataMiner 10.2.2.0, 10.1.0.0-CU11, and 10.0.0.0-CU22 onwards. Would it be possible to verify if you're running a version before the fix and Windows Server 2016?
Other than this I would verify the user executing the automation script has permissions on the elements it's updating.
ryan yahia Posted new comment 10th February 2022
ryan yahia commented 10th February 2022
Thanks Jens,
With the help of Pedro I found it was referencing a dve element which was unhandled.
