Passing Visio Alarm Info to Element/Automation
Solved2.45K views16th June 2021alarm data Visio Visual Overview Visuals
Blake Smethers [SLC] [DevOps Advocate]1.22K 16th June 2021 0 Comments
I have a dynamic list of alarms, and I'd like to add a button that passes the alarm information to a parameter in an element. This parameter will then create a ticket:
The shapes are generated dynamically using the Children | Alarm on the group.
Is there a way to grab the alarm data and pass it to an element through a parameter? For example in an Execute | Set|TicketGenerator|999|AlarmName:[alarmname]|ConfirmationMessage=Are you sure you want to generate a ticket?
The other idea I had was to pass the alarm to an automation and then use the automation to parse the alarm and send the information to the parameter. Is that possible?
Thanks in advance for any information.
Blake Smethers [SLC] [DevOps Advocate] Selected answer as best 16th June 2021
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 16th June 2021 3 Comments
As of version 10.0.2, it's possible to use info keywords in all data items of a shape linked to an alarm, see RN24485.
With this, you can directly execute an automation script, set a parameter or set a session variable. From there, anything is possible.
Blake Smethers [SLC] [DevOps Advocate] Posted new comment 17th June 2021
Blake Smethers [SLC] [DevOps Advocate] commented 16th June 2021
Great information, thank you for that Sebastiaan answering the original question.
Follow up question – the button is nested in the “parent” group, and then the Child (of which represent alarms). However the button is not clickable. How do I make the button still clickable within the child groups?
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 16th June 2021
You’ll probably need to disable the parent shape and enable the child shape.
Blake Smethers [SLC] [DevOps Advocate] commented 17th June 2021
You’re the best Sebastiaan, as always thanks!
