Passing Script Parameters using a correlation action to C#
Solved2.56K views20th February 2023
9
Oliver Wilkinson [DevOps Advocate]871 20th February 2023 0 Comments
Apologies, I know it will likely exist but I have been unable to find documentation when I was looking.
I am hoping to trigger a script from a correlation on an alarm, subsequently I will then need to do a lookup and trigger an alarm on a separate element. I can see there is a configurable option for ‘Evaluate Script Parameter Values’
I wondered if there is a way I can pass information about the alarm that triggers the script to the C# code so that I can action on parameters that exist in it? i.e. the ID of the alarm or the values that are present within it?
Many thanks
Oliver
Tom Waterbley [SLC] [DevOps Enabler] Answered question 20th February 2023
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 20th February 2023 1 Comment
Hi Oliver,
This is certainly possible. See the bottom note at Running an Automation script from a Correlation rule
Jens Vandewalle [SLC] [DevOps Advocate] Edited answer 20th February 2023
Oliver Wilkinson commented 20th February 2023
Thank you!
9
Tom Waterbley [SLC] [DevOps Enabler]10.01K Posted 20th February 2023 1 Comment
Hi Oliver, see the note at the bottom of the following page: https://docs.dataminer.services/user-guide/Advanced_Modules/Correlation/Adding_rule_actions/Running_an_Automation_script_from_a_Correlation_rule.html
“To pass information about the alarm that triggered the Correlation rule to the script, you can use the special parameters with ID 65005 and 65006. For more detailed information, see Special parameters available in DataMiner Automation scripts.”
Thank you!
